twizzle Posted August 23, 2007 Share Posted August 23, 2007 Im putting a 200tdi (disco)engine in the series and the rad from the 200tdi is f____d what other rad can i use? i know some of you have done the 200tdi covertion TWIZZLE Quote Link to comment Share on other sites More sharing options...
selectcase Posted August 23, 2007 Share Posted August 23, 2007 You can use your series rad if you buy an aftermarket oil cooler(about £30 quid) . Use the top thermostat housing from your old 2.25 engine - it fits directly in place of the 200tdi one. you can then use a standard series top hose, on the bottom hose you ca use a combination of series hoses depending on if its a series 2a rad or a series 3 rad. Quote Link to comment Share on other sites More sharing options...
Tonk Posted August 24, 2007 Share Posted August 24, 2007 depends wot front end u're having, series/defender, the tdi is fine running on the series rad, although u'll have to run leccy fan. Quote Link to comment Share on other sites More sharing options...
twizzle Posted August 26, 2007 Author Share Posted August 26, 2007 depends wot front end u're having, series/defender, the tdi is fine running on the series rad, although u'll have to run leccy fan. im useing a series front because im trying to keep it as standerd as posable (headlights in frontpanel) TWIZZLE Quote Link to comment Share on other sites More sharing options...
