Mean Green Posted September 5, 2007 Share Posted September 5, 2007 Can anyone tell me if the windscreen wipers on a 1996 Disco is controlled by an ECU? Mine are playing up at the moment. When I first got it the intermittant did not work at all. Suddenly one day it worked fine and was OK for about 2 weeks. Now, they do not always stop when you switch off the wipers. I need to give the screen a wash and then after the 4 sweeps it stops again. Could this be an ECU fault or just a dodgy switch? Quote Link to comment Share on other sites More sharing options...
BogMonster Posted September 5, 2007 Share Posted September 5, 2007 There are some "multi function units" in the circuit diagram but it isn't really clear what they do. I suspect it is not as complicated as what you would normally call an "ECU" probably just a timer delay of some sort. Quote Link to comment Share on other sites More sharing options...
Ryan Posted September 5, 2007 Share Posted September 5, 2007 It appears from my copy of the Haynes Manual that the wipers do go through the multi-function unit (which is behind the glove box). Why they couldn't just use relays, I don't know.... I'm told that the mfu has a habit of losing bits of solder for the electric window control, so I would assume the same could happen for the wipers. Quote Link to comment Share on other sites More sharing options...
