walter Posted September 6, 2007 Share Posted September 6, 2007 hello there, my first post,and a quick thanks to everyone concerned for such an excellent forum, i have a problem with my disco and was hoping that possibly someone out there might have come across it before and be able to point me in the right direction, well here goes, sorry its long winded but it takes a bit of explaining, this first happened some months ago when the disco started to take longer and longer to fire up,it was totaly intermittant with no particular reason for it happening, there is a noise at the filter under the rear wheel arch that sounds as if air is getting into the system?steadily got worse, went into local non franchised landy garage who popped it onto the diagnostics and couldnt find anything wrong, kept it for the day and fault would not occur, changed filter and checked it out but could not find anything, next time it went in they put a new fuel pump into the tank, which seemed to make a difference, but only lasted a few days untill it started the same problem again, back into the garage, they found that there is a problem with the filter head so changed that, again seemed ok, done about 500 miles no probs at all now it has started again, exactly the same again, i am tearing my hair out (not to mention the garage mechanics) has anyone got any ideas? it is a 2002 td5, 70000 on the clock, but a brand new engine at 60000 miles, (under warranty, just before i got it) many thanks in advance, jd. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted September 7, 2007 Share Posted September 7, 2007 Try changing the injector washers that seal at the base of the injectors, between where it goes into the combustion chamber, and the fuel rail in the head. It's not a 5 min job because you need to dismantle the shaft that drives the injector plungers and then reset them all afterwards, but it might fix your problem. Quote Link to comment Share on other sites More sharing options...
walter Posted September 7, 2007 Author Share Posted September 7, 2007 Try changing the injector washers that seal at the base of the injectors, between where it goes into the combustion chamber, and the fuel rail in the head. It's not a 5 min job because you need to dismantle the shaft that drives the injector plungers and then reset them all afterwards, but it might fix your problem. cheers for the reply bog monster, the garage did mention that this could be the fault, but kinda thought it unlikely, reason being that it was not causing a problem when the engine was running,but just on start up, and the engine has only done 10,000 miles. dunno if their thinking is right but the options are getting less as time goes on,so they might have to try that anyway they said they are going to rig up some kind of guage so they can monitor the pressure of the fuel in the lines? will update when i find out . thanks, j.d. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted September 7, 2007 Share Posted September 7, 2007 just try it and see, when I first heard of this I thought it sounded daft too and said all the same things as you just did but it fixed the problem on 2 vehicles I know of just around here Quote Link to comment Share on other sites More sharing options...
walter Posted September 7, 2007 Author Share Posted September 7, 2007 just try it and see, when I first heard of this I thought it sounded daft too and said all the same things as you just did but it fixed the problem on 2 vehicles I know of just around here thanks again bogmonster, think i will just tell them to carry on and give it a go, got nothing to lose and everything to gain, it's got to the stage that i just dont trust the car,so if i can limp it along this week i am away next friday so i will give them the car for the week i am away and see how they get on. thanks again. will report back. j.d. Quote Link to comment Share on other sites More sharing options...
walter Posted September 7, 2007 Author Share Posted September 7, 2007 thanks again bogmonster,think i will just tell them to carry on and give it a go, got nothing to lose and everything to gain, it's got to the stage that i just dont trust the car,so if i can limp it along this week i am away next friday so i will give them the car for the week i am away and see how they get on. thanks again. will report back. j.d. just thinking, how come when they do something to the fuel tank area (pump, filter, etc) does it have a positive effect on things if it is the injectors at fault? sorry but it's just the way i think!! Quote Link to comment Share on other sites More sharing options...
BogMonster Posted September 8, 2007 Share Posted September 8, 2007 possibly coincidence! when I was having trouble with my old Discovery (which eventually turned out to be the alarm spider, as per the repair thread in the Tech Archive) I was ABSOLUTELY convinced that things I was doing around the ignition coil were having an effect, but intermittent faults play hell with your mind Quote Link to comment Share on other sites More sharing options...
walter Posted September 11, 2007 Author Share Posted September 11, 2007 possibly coincidence!when I was having trouble with my old Discovery (which eventually turned out to be the alarm spider, as per the repair thread in the Tech Archive) I was ABSOLUTELY convinced that things I was doing around the ignition coil were having an effect, but intermittent faults play hell with your mind hi there again, was away today in my disco came to start it, took ages then when it did go, there was a louder than normal buzzing from the pump, i have dumped the car at the nearest main dealers, and told them to keep it till its sorted will keep y'all informed of any progress. Quote Link to comment Share on other sites More sharing options...
walter Posted September 27, 2007 Author Share Posted September 27, 2007 hi guy's quick update, the main dealer has changed the filte head,(under the wheel arch) they recon that they can sometimes get porous, allowing air in,i dont see how air can get in if diesel is not gettin out, specially when it is under pressure?????, but there you go, will keep my fingers crossed, and let yall' know if anything develops. thanks again. j.d. Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted September 27, 2007 Share Posted September 27, 2007 A real garage should not just change bits and hope for the best (though LR stealers do this and you foot the bill). The thing to do is to use transparent tubing and find out exactly where the air is getting into the system. If your injector washers are leaking you will get air in the outlet from the cylinder head at the fuel cooler. And so on. The last one we had had air in the LP first stage connection to the filter. And then the air went to the engine. New pump fixed that. Expensive, though. Quote Link to comment Share on other sites More sharing options...
