goaty Posted October 1, 2007 Share Posted October 1, 2007 Hi, I recently stumbled upon a spare front axle, its a 1996 300tdi defender front axle with vented discs but i have a problem with one of the output shafts. I thought it may have been the drive flange having its thread stripped but it turns out it is the CV shaft thats got ruined splines. Now i am planning on fixing it but i am unsure how and which part i need to buy, can anyone help? Also is it worth buying the cheaper pattern parts or is my money better going on a Hardy spicer or similar, which are double the cheaper ones. Any info and help.....please. thanks joe Quote Link to comment Share on other sites More sharing options...
JST Posted October 1, 2007 Share Posted October 1, 2007 just replacement CVs and hub drive member gasket, plus the lock tab washer for when redo the bearings. if bearing are suspect i would change them and the rear disk oil seal at the same time. Quote Link to comment Share on other sites More sharing options...
goaty Posted October 1, 2007 Author Share Posted October 1, 2007 just replacement CVs and hub drive member gasket, plus the lock tab washer for when redo the bearings. if bearing are suspect i would change them and the rear disk oil seal at the same time. Any chance of a quick qalk through of changing a CV?? Just which bits i need to remove, i am sure i could work it out but just havent got time to look at it at the mo, also unsure which CV i need. Thanks again Quote Link to comment Share on other sites More sharing options...
SteveG Posted October 2, 2007 Share Posted October 2, 2007 easier to look it up in the tech archive, it's all there with pictures to help. Use the Index at the top Cheers Steve Quote Link to comment Share on other sites More sharing options...
goaty Posted October 2, 2007 Author Share Posted October 2, 2007 i looked in there but didn't see it Quote Link to comment Share on other sites More sharing options...
SteveG Posted October 2, 2007 Share Posted October 2, 2007 i looked in there but didn't see it Here's one, for a Disco but it's the same for a Defender. http://forums.lr4x4.com/index.php?showtopic=5601 Look under 'How To' and Drivetrain. There are loads of posts on hubs and bearings. Cheers Steve Quote Link to comment Share on other sites More sharing options...
goaty Posted October 2, 2007 Author Share Posted October 2, 2007 Nice one, i was being a tard by the looks of it. cheers for the help Quote Link to comment Share on other sites More sharing options...
