JST Posted October 7, 2007 Share Posted October 7, 2007 Original '88 TD 90. changed the bulkhead and now the reverse light doesn't work. the issue IS in the plug from the wires on the back of the gearbox to the multiplug on the engine side of the bulkhead. in other words over the 3mth period i took to change the bulkhead i forgot where the wires were meant to go, so they aren't connected properly. Does anyone know where (ie which plug/leads and where it is, what it looks like) the two wires that come off the back of the G box reverse switch positon locater should attach to the main vehicle loom? thank you in advance Quote Link to comment Share on other sites More sharing options...
western Posted October 7, 2007 Share Posted October 7, 2007 the switch wires connect --- green/yellow to green/brown green to green at the bulkhead find the rubber connector that has these going into it [haven't listed all the wires in the plug as I can't remember all of them] white/yellow purple/orange green white/purple connect the reverse switch green to the green & the green/brown to it's matching single bullet connector also green/brown. had to play with my reverse light/switch wiring this afternoon, so this is hot of my memory banks Next time you'll label everything Quote Link to comment Share on other sites More sharing options...
JST Posted October 8, 2007 Author Share Posted October 8, 2007 Cheers Ralph, thats exactly what i needed will have a look this pm/tomorrow Thank you Quote Link to comment Share on other sites More sharing options...
western Posted October 8, 2007 Share Posted October 8, 2007 I'll add a photo when home from work later. Quote Link to comment Share on other sites More sharing options...
western Posted October 8, 2007 Share Posted October 8, 2007 I'll add a photo when home from work later. photo of connector & reverse light wires [green & green/brown tracer] as promised the green & green/brown wrapped together go to the reverse light switch on the gearbox, the lower green/brown runs to the rear of the vehicle & reverse lights hth Quote Link to comment Share on other sites More sharing options...
JST Posted October 11, 2007 Author Share Posted October 11, 2007 Had a look today, photos were a bonus Ralph (thank you) they confirmed that i HAD actually got it right! (lord knows how) anyway it seems the reverse switch into the G box is knackered. No continuity across it when in reverse regardless of how far its screwed in. if i bypass the switch and connect the wires together - the light comes on! So new switch ordered. next question is how far do you screw the switch in? Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted October 11, 2007 Share Posted October 11, 2007 next question is how far do you screw the switch in? select reverse, wind the switch in, say half a turn at a time, and after each turn, stick a meter (or connect the reverse light connections) and see it the switch has "made", once it has, you could go another 1/4 or 1/2 turn just to be sure, then lock off the lock-nut. don't wind it in too far otherwise reverse won't engage properly, or the detent spring things might not "click" properly, and it'll ping out of reverse. Quote Link to comment Share on other sites More sharing options...
western Posted October 12, 2007 Share Posted October 12, 2007 Wot DJ said ^^^^ glad the photo & info helped. Quote Link to comment Share on other sites More sharing options...
JST Posted October 22, 2007 Author Share Posted October 22, 2007 Cheers guys, all fitted and works a treat - THANK YOU. Quote Link to comment Share on other sites More sharing options...
western Posted October 23, 2007 Share Posted October 23, 2007 Cheers guys, all fitted and works a treat - THANK YOU. Quote Link to comment Share on other sites More sharing options...
Early90 Posted October 24, 2007 Share Posted October 24, 2007 I have to say thanks too! My reversing light had not worked since coming back from a chassis change, i knew it was wired wrong and i was dreading sorting it out. All good now, thanks. Quote Link to comment Share on other sites More sharing options...
