V8 Freak Posted October 17, 2007 Share Posted October 17, 2007 Friends TDi has started making a funny noise.... It occurs rythmicaly with the engine revs, can be heard through the air intake. Sounds like a popping noise or as if you were knocking a stick against a wooden / bamboo tube in time with the engine. (Removal of the air filter makes it quite loud.) He believes engine performance may be down but not driven far since the noise started. Any suggestions ? Anything to check ? Thanks in advance Neil Quote Link to comment Share on other sites More sharing options...
white90 Posted October 17, 2007 Share Posted October 17, 2007 head gasket would be a suspect Quote Link to comment Share on other sites More sharing options...
Les Henson Posted October 17, 2007 Share Posted October 17, 2007 Popping out of the inlet manifold could be a valve problem. Tell him to check his tappet gaps - otherwise head off by the looks of it. Les. Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted October 17, 2007 Share Posted October 17, 2007 Mine made a sort of chuffing noise in the air intake once. It was caused by broken valve stem caps which made the gap about .9mm instead of .2 as it should be. You should follow Les's advice I think. Quote Link to comment Share on other sites More sharing options...
V8 Freak Posted October 17, 2007 Author Share Posted October 17, 2007 Thanks for the pointers guys.... He's taking it in for proper disgnosis tomorrow..... Neil Quote Link to comment Share on other sites More sharing options...
Troddenmasses Posted October 18, 2007 Share Posted October 18, 2007 He's taking it in for proper disgnosis tomorrow.....Neil [sucks air past teeth] That'll cost you. [/sucks air past teeth] Quote Link to comment Share on other sites More sharing options...
V8 Freak Posted October 18, 2007 Author Share Posted October 18, 2007 Hehehe... Cost him you mean... Quote Link to comment Share on other sites More sharing options...
