tand Posted October 22, 2007 Share Posted October 22, 2007 hi does any one know if a tdi200 defender turbo and manifold will fit a disco tdi200 engine when in a defender Quote Link to comment Share on other sites More sharing options...
simonb Posted October 22, 2007 Share Posted October 22, 2007 hi does any one know if a tdi200 defender turbo and manifold will fit a disco tdi200 engine when in a defender Yes if you can find one! Quote Link to comment Share on other sites More sharing options...
JST Posted October 22, 2007 Share Posted October 22, 2007 dont you have to change the timing cover as well? Quote Link to comment Share on other sites More sharing options...
Guest WALFY Posted October 26, 2007 Share Posted October 26, 2007 James is correct. If you want to fit a Def intake manifold/turbo/exhaust bits then you have to change the whole front of the engine. Unless you have an uprated turbo or a special it's probably not worth the effort in my opinion. All the bits are avail easily. Tming chest is about 140 ish and the alt bracket 70 if you buy new. Trying to source all the bits second hand takes time and patience. Quote Link to comment Share on other sites More sharing options...
zulublue Posted October 26, 2007 Share Posted October 26, 2007 I have not long done this, as I was silly and purchased my 90 and after 3 day's drove it through 4ft of water without checking the snorkel Anyway I got hold of a 200Tdi from disco, and tried fitting and soon found out oh sugar this is going to be fun, so we removed the front case and swapped it over, but then it would not line up with the gearbox, so beware of the stud placements, I think we changed everything in the end and just kept the disco block. I know there are conversion kits for the exhaust, someone will give you the name of them, but the main bit of advice I would use is keep it as original as possible. Quote Link to comment Share on other sites More sharing options...
sean f Posted October 26, 2007 Share Posted October 26, 2007 Other option is to fit a 300tdi turbo. It bolts straight on you just have to change some of the manifold studs out for longer ones. The problems are: The manifold will foul the oil dipstick, just bend it and it will fit The exhaust is now directly over the engine mount. I cut and welded the 200tdi disco exhaust outlet and made it fit. I did this about a year ago and it goes fine, the only problems I have had is with the exhaust and thats due to my dodgy fitting the first time round and has now been fixed. I left the boost standard for a 300tdi so slightly high for a 200tdi. Mostly this was done as I had a spare 300 manifold sitting around and was trying to make it easy, didn't work out easy but once I started fitting it though I may as well finish. The origional 200tdi turbo is now in Honiton Hobbits shed, which come to think of it he still owes me for! Quote Link to comment Share on other sites More sharing options...
