Anglo-Frenchman Posted October 24, 2007 Share Posted October 24, 2007 Hi, I'm shortly replacing my oil pump and am not sure if the 200tdi has a sump gasket to replace. The Haynes book says replace where necessary but this suggests that some are not fitted. I cannot see any evidence of one on the vehicle so could it just be a case of joint sealer? The pump comes with a small gasket and sealing ring but these are obviously where it mounts onto the bottom of the block. Ged Quote Link to comment Share on other sites More sharing options...
Matt Neale Posted October 24, 2007 Share Posted October 24, 2007 Hi,I'm shortly replacing my oil pump and am not sure if the 200tdi has a sump gasket to replace. The Haynes book says replace where necessary but this suggests that some are not fitted. I cannot see any evidence of one on the vehicle so could it just be a case of joint sealer? The pump comes with a small gasket and sealing ring but these are obviously where it mounts onto the bottom of the block. Ged Mine was sealed with joint sealer / silicone - from the factory. No sump gasket as such to speak of. Matt Quote Link to comment Share on other sites More sharing options...
Les Henson Posted October 24, 2007 Share Posted October 24, 2007 Only RTV sealant in my eperience - even the earlier TD engines were sealant although a series sump gasket fits. Les Quote Link to comment Share on other sites More sharing options...
Anglo-Frenchman Posted October 24, 2007 Author Share Posted October 24, 2007 Thanks very much for the heads-up. Ged Quote Link to comment Share on other sites More sharing options...
western Posted October 24, 2007 Share Posted October 24, 2007 RTV sealant LR part STC611 if you want the proper stuff Quote Link to comment Share on other sites More sharing options...
