TheBeastie Posted October 27, 2007 Share Posted October 27, 2007 I am currently using my TomTom Go 510 (I think) powered through the cigar lighter attachment. I hate the bulk of it and wondered if I could somehow attach the cables through a permanent fused and switched power supply so that it was all out of sight but as soon as I put switch on then the satnav got power. If I could then all would be that bit neater and I would be a happier man. I presume the big chunky bit that goes in the cigar lighter is some sort of either transformer or else power cleaner. Has anyone done this before and can tell me what I need to do? Thanks Malcy Quote Link to comment Share on other sites More sharing options...
western Posted October 27, 2007 Share Posted October 27, 2007 the big chunky bit would be the voltage/current dropper/charger, if hard wiring this you may inadvertantly supply to much current/voltage to the TomTom unit. Quote Link to comment Share on other sites More sharing options...
Mark90 Posted October 27, 2007 Share Posted October 27, 2007 You could still hard wire it in by wiring free floating a ciggy socket behind the dash and permanently plugging the TT into that, just tape it up well to ensure it doesn't come loose. This will allow you to keep the voltage dropper/regulator that is in the TT ciggy plug. Just wire the additional ciggy socket though a fuse and a switch if thats what you want. Quote Link to comment Share on other sites More sharing options...
western Posted October 27, 2007 Share Posted October 27, 2007 or hide it in the battery bay or in the compartment under the drivers seat & extend the wiring upto the dash. Quote Link to comment Share on other sites More sharing options...
TheBeastie Posted October 28, 2007 Author Share Posted October 28, 2007 Thanks guys I linke the idea of just taping it into a hidden cigar lighter and then wiring up to the dash. I seem to recall there was not a lot of space under the drivers seat in my 90 since most of it was fuel tank but will explore since the battery box is getting quite full now I have got my cut off switch and a 8 way fuse box for feeds direct from battery - all except the radio code, clock and internal LED lighting will be from the other side of the switch so if it goes off so do all main electrics. Thanks again for the ideas Malcy Quote Link to comment Share on other sites More sharing options...
western Posted October 28, 2007 Share Posted October 28, 2007 could hid a extra cig socket under the cubbybox. wouldn't put it by the fuel tank under your seat. Quote Link to comment Share on other sites More sharing options...
TheBeastie Posted October 28, 2007 Author Share Posted October 28, 2007 wouldn't put it by the fuel tank under your seat. My thoughts had run that way too!!! It could make things go with a bang! Quote Link to comment Share on other sites More sharing options...
western Posted October 28, 2007 Share Posted October 28, 2007 My thoughts had run that way too!!!It could make things go with a bang! & could be potentially painfull for you Quote Link to comment Share on other sites More sharing options...
TheBeastie Posted October 28, 2007 Author Share Posted October 28, 2007 But would the SatNav follow the trajectory ? Quote Link to comment Share on other sites More sharing options...
western Posted October 28, 2007 Share Posted October 28, 2007 But would the SatNav follow the trajectory ? probably be in a million pieces. Quote Link to comment Share on other sites More sharing options...
