doddel Posted November 9, 2007 Share Posted November 9, 2007 does anybody know if Landrover exported pre-production LHD series II to Europe in 1957? Quote Link to comment Share on other sites More sharing options...
bill van snorkle Posted November 10, 2007 Share Posted November 10, 2007 Not sure about Europe but I have seen a couple of what I believed to be late 1957 RHD series 2 vehicles in Australia. these were fitted with the 2 litre F head petrol engine from the series 1 because as the story goes, demand and production of series 2 vehicles exceeded the supply of the then new 2 1/4 litre petrol engine, so Rover overcame the engine shortage by using up the remaining stock of 2 litre lumps and exported these vehicles to the Antipodes where we were so desperate for any 4wds that no one complained that the vehicle wasn't quite what it said on the tin. Bill. Quote Link to comment Share on other sites More sharing options...
doddel Posted November 10, 2007 Author Share Posted November 10, 2007 I have my eyes on a LWB with the 2L diesel. Have checked the documents, and it is a 1957 serie II. Collector's item? Quote Link to comment Share on other sites More sharing options...
David Sparkes Posted November 10, 2007 Share Posted November 10, 2007 "Have checked the documents, and it is a 1957 serie II. Collector's item?" If you want to create a verifiable provenance, that will withstand future scrutiny, and may be a financial asset, I'd say you have to ask the BMIHT at Gaydon, at least for a letter if not an (expensive) certificate. Alternatively, ask the appropriate officer at the Series 2 Club, although you may have to join to avail yourself of this service. If you use the VIN on the documentation you have, or the easy to read plate in the vehicle, you are taking a slight gamble. Ideally you want the VIN off the leading outside spring hanger of the front RH spring, although this isn't always obvious. requiring scraping to remove underseal and surface rust, plus polishing with a wire brush, to make the stamped in number distinguishable. HTH Quote Link to comment Share on other sites More sharing options...
