edwardatherton Posted November 20, 2007 Share Posted November 20, 2007 I am about to put a new tub on my Sankey, and a few people have said that I should get it galvanised first. Does anyone have any idea on likely cost, and where in the Manchester/Lancashire area to get it done? I carry all sorts in it, is the galv likely to get rubbed off/scratched etc? Quote Link to comment Share on other sites More sharing options...
101sean Posted November 20, 2007 Share Posted November 20, 2007 I am about to put a new tub on my Sankey, and a few people have said that I should get it galvanised first.Does anyone have any idea on likely cost, and where in the Manchester/Lancashire area to get it done? I carry all sorts in it, is the galv likely to get rubbed off/scratched etc? Don't know about where but they charge by kg used and amount of prep work. Probably £200 or so. Galvanising is pretty durable and small scratches will self repair to an extent, deep gouges will rust unless you slap some galvafroid on. If you're over painting you will have to T wash and etch prime. Lot of trouble to go to, they rot from the inside due to drain holes blocking and tub filling with water, keep them clear and it should be OK. Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted November 20, 2007 Share Posted November 20, 2007 Don't know about where but they charge by kg used and amount of prep work. Probably £200 or so. shouldn't be that much, i got a whole 110 chassis done with some crossmembers and it came to £219. they charge it by weight... they weigh the item prior to dipping, then afterwards, the difference in weight is how much zinc is stuck to it. Quote Link to comment Share on other sites More sharing options...
Phil Hancock Posted November 20, 2007 Share Posted November 20, 2007 A word of warning, on thin sheet sections it could well warp from the heat of galvanising, so your sides/floor end up all wavy. Quote Link to comment Share on other sites More sharing options...
