zulublue Posted November 21, 2007 Share Posted November 21, 2007 I have just purchased what was sold to me as a 1993 K plate disco rear Axel, I have no reason to doubt this apart from someone saying it looked like a RRC rear Axel, is there any way I can check? Secondly the reason for the change is to get disk brakes on the rear of my Defender, now the disks / calipers that came with it don't look to good, but I do have a 1982 RRC axel with new disks pads and good calipers on, can I just swap these over, will they fit straight on? or do I need to buy new ones? Mark. Quote Link to comment Share on other sites More sharing options...
Porny Posted November 21, 2007 Share Posted November 21, 2007 I have just purchased what was sold to me as a 1993 K plate disco rear Axel, I have no reason to doubt this apart from someone saying it looked like a RRC rear Axel, is there any way I can check?Secondly the reason for the change is to get disk brakes on the rear of my Defender, now the disks / calipers that came with it don't look to good, but I do have a 1982 RRC axel with new disks pads and good calipers on, can I just swap these over, will they fit straight on? or do I need to buy new ones? Mark. Disco and RR use the same axle... was one of 117 shared parts I think..... Ian Quote Link to comment Share on other sites More sharing options...
zulublue Posted November 21, 2007 Author Share Posted November 21, 2007 Cheers Oracle Ian Quote Link to comment Share on other sites More sharing options...
gruntus Posted November 21, 2007 Share Posted November 21, 2007 Hi Mark, Are the Shockie brackets facing in the same direction? I have just bought a K plate RR axle for my 90, if you need me to compare anything let me know. PS I will be heading away fr ra couple of days tomorrow but will look tonight if you need anything clarified or pictures taken Cheers G Quote Link to comment Share on other sites More sharing options...
zulublue Posted November 21, 2007 Author Share Posted November 21, 2007 On the new axel they are, but on my old RRC one they are opporsite ways, I only want to swap the disks and calipers over. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted November 21, 2007 Share Posted November 21, 2007 You *might* find the old axle is imperial and the new one metric, so some stuff may not be swappable. Quote Link to comment Share on other sites More sharing options...
Mark Posted November 21, 2007 Share Posted November 21, 2007 On the Disco axle, what do the ends of the halfshats looklike? If they look the same as the ones on the Rangie axle and havd 14mm head bolts in, then it should be imperial. If the ends of the shafts are much shallower and have 17mm head bolts then it is a metric axle. hth Mark Quote Link to comment Share on other sites More sharing options...
zulublue Posted November 21, 2007 Author Share Posted November 21, 2007 Great thanks Mark, they are the same as my RRC so imp it is then, save me a few quid. Quote Link to comment Share on other sites More sharing options...
GBMUD Posted November 21, 2007 Share Posted November 21, 2007 If they look the same as the ones on the Rangie axle and havd 14mm head bolts in, then it should be imperial. Come on Mark, 9/16AF not 14mm. A decent 14mm spanner will not fit, only Mark's Woolworth socket set. Chris Quote Link to comment Share on other sites More sharing options...
