tommi Posted December 11, 2007 Share Posted December 11, 2007 Hi My father has a 1994 300tdi Discovery. If it hasnt been started for day or two, it smokes badly when you start it up. It continues to smoke for about 5-10mins, and after that there is no smoke at all. The engine runs sweetly, and their is no nasty sounds coming from the engine. The smoke is white. Does anyone know what is causing this, or is it normal? Thanks in advance, Tom. Quote Link to comment Share on other sites More sharing options...
RRX Posted December 11, 2007 Share Posted December 11, 2007 What colour is the smoke, white, blue, black? Quote Link to comment Share on other sites More sharing options...
tommi Posted December 11, 2007 Author Share Posted December 11, 2007 The smoke is white. Thanks. Quote Link to comment Share on other sites More sharing options...
RRX Posted December 11, 2007 Share Posted December 11, 2007 Sounds like steam to me, is the water level ok? probably just collects also of water in the exhaust as it cools down and evaporates it when started if all seams ok with levels Quote Link to comment Share on other sites More sharing options...
tommi Posted December 11, 2007 Author Share Posted December 11, 2007 I dont think its steam but I may be wrong. Is their anything else it could be? Thanks, Tom. Quote Link to comment Share on other sites More sharing options...
RRX Posted December 11, 2007 Share Posted December 11, 2007 The only other thing that comes out as white smoke is oil burning in the exhaust housing on the turbo, but usually when a turbo oil seal fails they just empty all the oil either into the inlet and run away or exhaust and then sieze if not noticed due to no oil. Quote Link to comment Share on other sites More sharing options...
nickm Posted December 12, 2007 Share Posted December 12, 2007 mine has started to smoke (white) til its warmed up just put it down to the cold air Quote Link to comment Share on other sites More sharing options...
lynall Posted December 13, 2007 Share Posted December 13, 2007 Diesel burning wrong is also white ( black is over fueling) would agree with the cold weather comment, ie dont worry to much if it still does it when weather better then look into it further. Lynall Quote Link to comment Share on other sites More sharing options...
