smo Posted December 15, 2007 Share Posted December 15, 2007 From the image below, i have removed the bits highlighted in pink, however im left with all the other bits, some vacuum arrangement etc....which of them do i need to keep?? Quote Link to comment Share on other sites More sharing options...
Porny Posted December 16, 2007 Share Posted December 16, 2007 From the image below, i have removed the bits highlighted in pink, however im left with all the other bits, some vacuum arrangement etc....which of them do i need to keep?? None of it.... All you need is the main pipe from the vaccum pipe to the brake servo - all the take off points can be removed/blanked - or I can supply a vaccum pipe that doesn't have the take off points. Ian Quote Link to comment Share on other sites More sharing options...
treebloke Posted December 17, 2007 Share Posted December 17, 2007 None of it....All you need is the main pipe from the vaccum pipe to the brake servo - all the take off points can be removed/blanked - or I can supply a vaccum pipe that doesn't have the take off points. Ian I have recently done mine (300 tdi) but I am sure it was different to the one above, it had a pipe going into the top hose on the intercooler. Quote Link to comment Share on other sites More sharing options...
white90 Posted December 17, 2007 Share Posted December 17, 2007 Count the ports on the manifold Bob I'm guessing TD5 Quote Link to comment Share on other sites More sharing options...
smo Posted December 17, 2007 Author Share Posted December 17, 2007 Count the ports on the manifold Bob I'm guessing TD5 Correct, it was (is) indeed a TD5 Quote Link to comment Share on other sites More sharing options...
JST Posted December 17, 2007 Share Posted December 17, 2007 theres a thread on D4x4 with similar for td5 as well. Quote Link to comment Share on other sites More sharing options...
smo Posted December 17, 2007 Author Share Posted December 17, 2007 theres a thread on D4x4 with similar for td5 as well. That would be me too then!!!! All sorted now, whole lot ripped out and sorted Quote Link to comment Share on other sites More sharing options...
