pux Posted December 16, 2007 Share Posted December 16, 2007 Hi guys im after getting a new battery for my 300tdi discovery, i do run a winch and a couple of spotlights etc etc the problem being i cant afford to splash out £199 on a optima yellow top or red top battery, so does anyone know of a cheaper but just as good battery suited to my needs any help appreciated. Quote Link to comment Share on other sites More sharing options...
RRX Posted December 16, 2007 Share Posted December 16, 2007 Just make sure you get a sensible battery, or if you can fit one on the other side on the rad as all it needs it a link to the other battery. from the other thread running i think you'll be after a 072 type battery as the tray on the discovery is a bit small. Quote Link to comment Share on other sites More sharing options...
pux Posted December 16, 2007 Author Share Posted December 16, 2007 Just make sure you get a sensible battery, or if you can fit one on the other side on the rad as all it needs it a link to the other battery. from the other thread running i think you'll be after a 072 type battery as the tray on the discovery is a bit small.emm i can't really go down that route as where you would locate the second battery there is the home made snorkel coming up through into the front of the air box but cheers for the info i wqas going to post on that thread but did not want to hi jack it. Quote Link to comment Share on other sites More sharing options...
RRX Posted December 16, 2007 Share Posted December 16, 2007 Forgot the inlet was on the front of the airbox, Doh!, If you have a safari fitted you can make use of the area infront of the airbox for a battery. Quote Link to comment Share on other sites More sharing options...
wrcwrc Posted December 20, 2007 Share Posted December 20, 2007 Personally i'd just go for the biggest BOSCH battery you can fit in there. Cant really go wrong unless you are putting too much load on it without the engine running etc Quote Link to comment Share on other sites More sharing options...
DiscoClax Posted December 22, 2007 Share Posted December 22, 2007 Another option would be a Deka Intimidator. Same basic AGM construction as an Optima, but uses flat plates instead, so it's a brick instead of a six-pack. All the benefits of the Optima (vibration proof, no spill, no maintenance, deep cycle, high CCA, etc), but slightly higher energy density and significantly cheaper (at least in Oz). I researched the same thing about a year ago and was going to spend the big bucks on the Optima and then found out about the Deka. Yep, I got one... No problems at all, very happy with it. Fits in the standard hole and is rated to a very conservative 750+CCA - enough to drive a Warn 9000 pounder easy. I've seen independent tests where these things punch out well over 1,000 Cranking Amps at 0 deg C (32 deg F). Specs here.. I fitted the 9A34 model. http://www.eastpenn-deka.com/assets/base/1143.pdf Quote Link to comment Share on other sites More sharing options...
