JST Posted December 26, 2007 Share Posted December 26, 2007 Right then i have developed an annoying intermittent squeak which 'seems' to be coming from the rear n/s wheel station area. i only get it at low road speeds and when moving, engine running and stationary - no noise. ie i dont think its engine speed related. The noise is similar to that made by something caught between the disc and crud card. i have checked that there is nothing caught in there, plus its not the wheel bearings, prop UJs, pads or anything that jumps(!) into view when looking with the wheel off. I did think it may be the lower shock mounting - the bottom of the shock was just catching the metal of the cup it sits in so i replaced the bushes and it still does it. any ideas? Edited to add: the noise is worse when turning left! Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted December 26, 2007 Share Posted December 26, 2007 Movement in the trailing arm bushes ? Mo Quote Link to comment Share on other sites More sharing options...
treebloke Posted December 26, 2007 Share Posted December 26, 2007 Pinion bearing ?. Quote Link to comment Share on other sites More sharing options...
JST Posted December 27, 2007 Author Share Posted December 27, 2007 ummmmm, its got worse and not from the back now i think the inital back noise was the shock mounting sqeaking, npw have a new front noise!!! a new post to come. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted December 27, 2007 Share Posted December 27, 2007 The reason you've noise at the back and now the front is the turkey and sprouts you've eaten over Christmas Mo Quote Link to comment Share on other sites More sharing options...
JST Posted December 28, 2007 Author Share Posted December 28, 2007 Mo - good point but it does it when i am not in it as well!!! Quote Link to comment Share on other sites More sharing options...
