Matthew Posted December 29, 2007 Share Posted December 29, 2007 Hi, I've recently changed my axles for 24spline versions and i now want to get some caster correction arms for the new axles (which are obviously 45mm rather than 38mm) I'm running a 3inch lift at the moment, not really any plans to get any higher but certainly won't be going any lower! I've looked at the QT versions and they offer 3 degree for 2 inch lifts and 6 degree correction for 4 inch lifts. Which would be better to fit and why? What problems could I run into with too much correction? Has anyone else used 6 degree arms with a 3 inch lift? What effect would running the 3 degree arms give? (On and off road) What effect would running the 6 degree arms give? (On and off road) Thanks for any advice given. Matt. Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted December 29, 2007 Share Posted December 29, 2007 I'd go for the 3 degree ones... reason? well, some people get away with no castor correction on a lift (or the change in steering quality is negligable), so 3 degrees should see you well enough. if you have too much castor correction (and you may well get it with the 3 degrees) is that you'll get propshaft vibration, as the UJ on the diff end will be operating at a different angle to what it is designed to. you may need to get a double CV front propshaft. Quote Link to comment Share on other sites More sharing options...
white90 Posted December 29, 2007 Share Posted December 29, 2007 3 degree is plenty/ideal for 50mm lift Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted December 29, 2007 Share Posted December 29, 2007 Added: I've got a pair of scrapiron orange (although look identical to QT,grey in colour, so i suspect ripped off and re-packaged!) 3 degree arms here in Swindon if you want to try them, but they're the narrower type, so you'd have to make up a spacer, or press in the thicker bushes, or add some washers (short term! ) Quote Link to comment Share on other sites More sharing options...
Matthew Posted December 30, 2007 Author Share Posted December 30, 2007 Hi Jim and Tony, Thanks for the comments, I actually had some 3 degree arms perviously before I changed my axles and the setup seemed to work well (but thanks for the offer to try a set jim) The main reason I wanted to know about the effect of using the 6 degree arms is because I know a mate that has some nice ones kicking around that I can buy fairly cheap, but saving £50 or so isn't worth having the worng suspension set up IMHO. Thanks again guys! Matt Quote Link to comment Share on other sites More sharing options...
Escape Posted January 2, 2008 Share Posted January 2, 2008 Hi Jim and Tony,Thanks for the comments, I actually had some 3 degree arms perviously before I changed my axles and the setup seemed to work well (but thanks for the offer to try a set jim) The main reason I wanted to know about the effect of using the 6 degree arms is because I know a mate that has some nice ones kicking around that I can buy fairly cheap, but saving £50 or so isn't worth having the worng suspension set up IMHO. Thanks again guys! Matt A mate of mine has a Classic with about 3" lift. He uses it as a daily driver and it was rather dangerous at higher speeds due to incorrect castor. Instead of buying corrected radius arms, we decided to have the swivelball holes redrilled. A quick calculating showed 5° to be ideal. It now runs perfectly. Removing the swivelballs isn't too much work and the redrilling only cost 45€ (about 30£), so far cheaper then a set of radius arms. Quote Link to comment Share on other sites More sharing options...
