hope springs Posted January 1, 2008 Share Posted January 1, 2008 Hi all, at the risk of covering old ground I am in need of some advise with the following. I need to replace my rear axle (93 Defender 90) due to rotten shock mounts (one fallen off) and very suspect spring mounts.I have looked through all the forums I can find but without much result, I have been advised that any defender or disco rear axle will fit and the ratios are the same, plus the later disc brakes will improve the braking.Is this correct and do I need the disc brakes as these axles seem to be a lot dearer than the drum version,+ can someone advise a trustworthy supplier of these items or is there a thread somewhere on this forum that I can read. Thanks in anticipation. Hope springs. Quote Link to comment Share on other sites More sharing options...
kiall Posted January 2, 2008 Share Posted January 2, 2008 Cant u get them parts separte and wled them on am sure u can corrent me is am mistaken though i thought that would be easier Quote Link to comment Share on other sites More sharing options...
Les Henson Posted January 2, 2008 Share Posted January 2, 2008 The lower spring mounts can be replaced, Paddocks sell them for about £5 each. The lower shock mounts are repairable - the hole usually gets too big/oval. Spring seat bracket- http://forums.lr4x4.com/index.php?showtopic=19718 I did a tech thread on how to repair the lower shock mount, but it's vanished............... Les. Quote Link to comment Share on other sites More sharing options...
gruntus Posted January 2, 2008 Share Posted January 2, 2008 Lower Shock mounts and axle links can be replaced as well from MPS4x4 Hope this helps Cheers G Quote Link to comment Share on other sites More sharing options...
hope springs Posted January 4, 2008 Author Share Posted January 4, 2008 Hi gents, thanks for the replies. I looked at replacing the mounts, but the axle case is a bit thin.I have been looking for a defender/disco axle but they all seem to be silly money. Can anyone recommend a good supply of these things. I have been offered a Range Rover axle which looks to be in good nick, are these a straight swap or is it not worth considering. Many thanks again for the help. Hope Springs Quote Link to comment Share on other sites More sharing options...
