The Homba Posted January 2, 2008 Share Posted January 2, 2008 Hi i was wondering if one of you kind people could tell me were i can get the rear cross member mounting things for the rear tub for a 110 csw i have looked for them on a few web sites but cant find them , also do you need to remove the tub to fit or would it be easier and cheaper to make some myself from some bar . Cheers Iain Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted January 2, 2008 Share Posted January 2, 2008 If you mean the pressed steel braces that run under the rear floor, they're available new from Paddocks and the like for around £12 each, except the wider one that goes under the rear seats of a CSW which I made myself by folding up a channel, notching it and capping it from ~1mm galv sheet. Not technically difficult but if I could've just bought one I would. Part number is 330265 or possibly superseded now. I know I bought a set less than a year ago from Paddocks. Quote Link to comment Share on other sites More sharing options...
The Homba Posted January 4, 2008 Author Share Posted January 4, 2008 Thanks mate thats what i was talking about will check paddocks out for them but do you need to remove the tub to fit them Cheers Iain Quote Link to comment Share on other sites More sharing options...
OilIT Posted January 4, 2008 Share Posted January 4, 2008 Thanks mate thats what i was talking about will check paddocks out for them but do you need to remove the tub to fit themCheers Iain yes i think you do as they are rivited onto the bottom of the tub, and invaribly you find the ridge in the flooring that they get rivited to has gone to powder so you need to do a bit of fabrication to be able to re-rivet the new brackets on (if you want to do it properly) Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted January 4, 2008 Share Posted January 4, 2008 What he said ^^^ looking at pics from my build you may be able to do it by lifting the tub up a bit rather than actually removing it but you may encounter a cross-member in the way or such like depending on your vehicle. I riveted mine on where the rivet holes were still good, and used a liberal bead of Sikaflex to make up for the rivets that were missing. Quote Link to comment Share on other sites More sharing options...
The Homba Posted January 5, 2008 Author Share Posted January 5, 2008 Thanks guys thats what i wanted to know will wait till the better weather to do it need to do the rear cross member to it collapsed when jacking it . Iain Quote Link to comment Share on other sites More sharing options...
