cxn Posted January 9, 2008 Share Posted January 9, 2008 hi all i have got a freelander 2.0 di on a t reg the stereo is working fine, but i havent got a code for it, is there anywhere i can get this code from in case my batterey dies or it requests the code. also what make stereo is it my cd changer is phillips, but it just says land rover on the stereo, r770. thanks in advance for any help ooops sorry common sense just kicked in if its a phillips cd changer as standard then there not going to use a kenwood head unit. so its a phillips head unit. Quote Link to comment Share on other sites More sharing options...
JCB Posted January 9, 2008 Share Posted January 9, 2008 Try the stealers! I got mine from there for an 02 model - it just came up on the computer when they put the reg in. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted January 10, 2008 Share Posted January 10, 2008 Dealership, using the VIN number and you will probably need proof of ownership Quote Link to comment Share on other sites More sharing options...
potshot Posted January 10, 2008 Share Posted January 10, 2008 I too have an 02 plate freelander and the dealers said that there is no code for this vehicle...I phoned up the local Rover place and gave the reg and they looked it up without any of the questions...give them a ring it is the simplest answer. Quote Link to comment Share on other sites More sharing options...
cxn Posted January 16, 2008 Author Share Posted January 16, 2008 well i got my code off the interenet for free at the below address, just in case any one else needs it. all you have to do is register (free) then post the serial number off your radio, they also do other radios ford, vaux, etc. http://www.31bubblegum.proboards54.com/ Quote Link to comment Share on other sites More sharing options...
