Landy 90 Hybrid Posted January 11, 2008 Share Posted January 11, 2008 Hi all, my first post so here goes. The gearlever on my ZF auto box is very stiff to move through the PRND321 range. Does anyone have any ideas? Kind regards Jonathan Quote Link to comment Share on other sites More sharing options...
DEANO3528 Posted January 11, 2008 Share Posted January 11, 2008 When mine did this it was mud that had got up onside the cable, wearing the inner on the bend. Solved when I changed the box as I used the one from the donor motor which hadn't been offroaded. New cables are a horrendous price I warn you! Quote Link to comment Share on other sites More sharing options...
bishbosh Posted January 11, 2008 Share Posted January 11, 2008 Before you go out spending loads of cash, try dismantling the trim so you can access the base of the gearstick. You may be able to spray WD40 or similar onto the selector shaft and work the lever through its full range. Obviously this will take a few goes to get a significant amount of lubrication along the length but it might help. Also, get under the truck and check the routing of the cable. It should run along the passenger side of the gearbox (RHD models) to the actuator tht goes throught eh gearbox casing. If there are kinks or similar that won't help. Quote Link to comment Share on other sites More sharing options...
istruggle2gate11 Posted January 11, 2008 Share Posted January 11, 2008 In my experiance, it really is worth taking an hour out and fully stripping the selector house (gear stick box). I suffer from a stiff stick regularly , its a down side to megasquirt and wading! The box strips down fairly easily, just a few screws and circlips to contend with, take the slider shaft out and emery it up, douse everything with copper slip or chain grease etc. Whatever you do, dont start forcing it, the little bobble on the side of the stick (the bit which moves the cable) can snap (its only brazed on, but does weld back on). Never had trouble with the cable but as mentioned in the above posts, seen a few who have. Quote Link to comment Share on other sites More sharing options...
DEANO3528 Posted January 12, 2008 Share Posted January 12, 2008 Yep I tried filling the bottom of the housing with light oil so the cable entry was always picking it up. Never made any difference at all, unfortunately. Quote Link to comment Share on other sites More sharing options...
Landy 90 Hybrid Posted January 12, 2008 Author Share Posted January 12, 2008 Cheers for that guys. Its on a Range rover/90 hybrid that I have just bought from a guy in my local club. The gear lever is in the middle, where the centre seat should be, and I have no trim to remove so can see the whole lot (top down). I havent had a look underneath yet but will do and check the route of the cable. I phoned ascrofts yesterday, and they also said about the cable possibly rusting and swelling inside the outer cable, so dismantle, emery paper, silicone grease and give it a try. Kind regards Jonathan Quote Link to comment Share on other sites More sharing options...
DEANO3528 Posted January 12, 2008 Share Posted January 12, 2008 I had oil coming out underneath but it didn't make the action any lighter, unfortunately. Only the replacement s/h one made a difference. With luck yours might be ok. Quote Link to comment Share on other sites More sharing options...
