yellowmitch Posted January 15, 2008 Share Posted January 15, 2008 Hi there. I have an 89 rangie which originally had a 3.5v8 in it. It now has a 200Tdi in it, which is great! Thing is, when I got it, pretty much everything worked with the exception of the heater plugs. I would like these to work and have bought a genuine Lucas red glow plug timer relay. My question is, how do I wire this up? I need to wire the plugs up themselves firstly (they are fitted and linked together with loops of wire) Then I need to wire the relay up to the plugs and finally, I need the relay connected to the ignition live and the output of it (which I presume goes to the plugs) to also illuminate the choke lamp in the binnacle Hence, hey presto, I will have a retro fitted glowplug heating system So how do I do it and what are the pins on the relay timer? Yay!! Quote Link to comment Share on other sites More sharing options...
bishbosh Posted January 16, 2008 Share Posted January 16, 2008 Where are you located? I have a 200TDi in my Rangie and have never bothered with the heater plugs. Half way through my second winter with no problems at all. Quote Link to comment Share on other sites More sharing options...
JST Posted January 16, 2008 Share Posted January 16, 2008 try here: Glow plug wiring question failing that search again thats how i found this old thread of mine. Quote Link to comment Share on other sites More sharing options...
TJ101 Posted January 16, 2008 Share Posted January 16, 2008 Ditto, same as Bish,, have a 200Tdi in a Rangie,,not needed any heat plugs so far but then it has got 4 cylinders missing, and runs on some smelly stuff,, mmm V8,, proper engine Quote Link to comment Share on other sites More sharing options...
