Paddy_SP Posted January 28, 2008 Share Posted January 28, 2008 I've got a mate here at the moment - his 1989 90 won't engage high-ratio after a session off-road - is there anything obvious that we can check? Quote Link to comment Share on other sites More sharing options...
disco_al Posted January 28, 2008 Share Posted January 28, 2008 linkages on the transfer box? Quote Link to comment Share on other sites More sharing options...
Top90 Posted January 28, 2008 Share Posted January 28, 2008 ^^^^ What he said. Make sure it's not a fault with the linkage before looking at the box. Quote Link to comment Share on other sites More sharing options...
neil00001 Posted January 28, 2008 Share Posted January 28, 2008 http://forums.lr4x4.com/index.php?autocom=...si&img=4205 Look at he diagram, parts 4 and 19 are held togeather with a grub screw, i had the opposite to your friend, couldnt engage low range, grub screw was loose...... Hope this helps cheers, Neil Quote Link to comment Share on other sites More sharing options...
Paddy_SP Posted January 28, 2008 Author Share Posted January 28, 2008 http://forums.lr4x4.com/index.php?autocom=...si&img=4205Look at he diagram, parts 4 and 19 are held togeather with a grub screw, i had the opposite to your friend, couldnt engage low range, grub screw was loose...... Hope this helps cheers, Neil Thanks for the helpful suggestions chaps - as my 110 is part-stripped, I suggested we take a close look at the linkages on it so he'd have a better idea of what he's got to check. He's now gone home (albeit at a low speed) to do just that. Edited to add: I can't get the link to work... Quote Link to comment Share on other sites More sharing options...
