Sankey Trailer Question
JonJon
THe Sankey probably hasn't got auto reverse brakes? Or if they have then the auto reverse bit isn't working or is seized.
I have a Sankey but when mine did that I engineered a permanent solution in about 2 min that involved a set of bolt croppers :ph34r:
Probably needs to be moved to the Military forum
They are laughing at you (and not the trailer) because you're supposed to get out and lock the trailer's break (drop a pin in a hole) before reversing. Then remove the pin when you're done maneuvering. The Sankey doesn't have auto-locking brake for reversing (unless someone modified it).
P.S. BogMonster was faster ...
Thanks! I'll post it there now. (But what did you do with the bolt-croppers?)
It's obvious they were laughing at me, but it's not obvious where I put the pin. Maybe I can't see it for staring!
