Struggling to select reverse?
nicnac
Hi,
I am having problems selecting reverse most of the time, all the other gears seem fine although the clutch does seem stiff, any ideas what this is or is it the case of a new clutch? its a TD4 and has done 63k
cheers
Could be clutch as you say
is it better if you dobblede clutch
Hi,
cheers
Silly question, but guess that u are going through the gate of 2nd before going into reverse?
I have been speaking to my local garage and they say it could be a number of things causing it from the gearbox itself, master cylinder, slave cylinder or the clutch and could cost upto £1300 depending what needs to be replaced :( is there a way to determine what is the problem without spending £100's on diagnostics?
