ronnie_rotten Posted March 1, 2008 Share Posted March 1, 2008 Hello peeps. I did a bit of a silly thing during the floods the other week. I neglected to notice how low the air intake pipe was on my 200. The result- bent con rod. Anyhoo, engine out, 2nd hand rod, reusing my piston, head gasket, new oil and filter, bish bash bosh, back together and i'm a clever boy. Sort of. It smoked like hell for a couple of miles, but it soon cleared up. However, it's really smokey on startup, and it used to be fine. What do we think? Oil creeping into the bores somehow or basically just general damage from the ill advised wading? Quote Link to comment Share on other sites More sharing options...
western Posted March 1, 2008 Share Posted March 1, 2008 Did you check the pushrods & valves for damage, the pushrods can be quite easily bent, even if slightly out of true they will affect the valve clearances & running. Quote Link to comment Share on other sites More sharing options...
ronnie_rotten Posted March 1, 2008 Author Share Posted March 1, 2008 Did you check the pushrods & valves for damage, the pushrods can be quite easily bent, even if slightly out of true they will affect the valve clearances & running. The push rods looked fine to my eye, as for valves i dunno. Head just got a bit of a clean up before it went back on. Would the smoke clear after a couple of minutes if it was that? Quote Link to comment Share on other sites More sharing options...
treebloke Posted March 1, 2008 Share Posted March 1, 2008 Not sure if I am reading your post right, you say you used new oil and filter but it seems you reused your head gasket?. Quote Link to comment Share on other sites More sharing options...
western Posted March 1, 2008 Share Posted March 1, 2008 would probably smoke for longer, check the timing just in case the belt has jumped one tooth or the piston ring gaps are all aligned so oil can get past them. did any water get into the fuel tank, maybe some did & it's being burnt off. Quote Link to comment Share on other sites More sharing options...
ronnie_rotten Posted March 1, 2008 Author Share Posted March 1, 2008 Hmm. Does read like i reused the gasket! Be assured, i got a new one. I'm using my mobile not a pc so this is all written sms style, so my proof reading is a bit lacking! I suppose water could have got to the tank, it needs a new front bracket anyway so I'll drain it and see. Timing could be worth a check. I got a mate who can do that. Quote Link to comment Share on other sites More sharing options...
ronnie_rotten Posted March 1, 2008 Author Share Posted March 1, 2008 Oh yeah, i made sure the piston ring gaps were staggered. Quote Link to comment Share on other sites More sharing options...
western Posted March 1, 2008 Share Posted March 1, 2008 Can't think of anything else to check, once that lot has been sorted. hope it's not any more serious. Quote Link to comment Share on other sites More sharing options...
ronnie_rotten Posted March 1, 2008 Author Share Posted March 1, 2008 Well if that covers it all then hopefully i can get it sorted. If not, I'll drive it til it goes bang and worry about it then. Cheers guys. Quote Link to comment Share on other sites More sharing options...
western Posted March 1, 2008 Share Posted March 1, 2008 In the Tech Archive index is a link to a diesel engine fault diagnosis sheet, I added a while back, it might be very usefull. Quote Link to comment Share on other sites More sharing options...
