TheBeastie Posted March 7, 2008 Share Posted March 7, 2008 Having removed the Jate rings from the front since I can use the rings on the steering guard I want to fit them on the back but my chassis seems to be different from pictures I have seen. These show fitting the Jate rings where the tow ball supports come off but on mine (see image) these are sort of studs welded onto chassis. I tried fitting the rings where there are holes to the rear of the tow ball support attachment but the mouth of the rings is about 10mm too wide so they sit very slack. Is it OK to pack out with washers so they sit tight or would this not be a clever idea. Equally is this particular point of fixing strong enough? Thanks - Malcy Edit - image not brill - the tow ball bits come from the bottom and I am referring to the smaller (10mm) holes on the chassis Quote Link to comment Share on other sites More sharing options...
Godlykepower Posted March 7, 2008 Share Posted March 7, 2008 To attach jate rings at the rear....you need to remove the lashing points (those eliptical shaped bits!), then the jate ring will sit on either side of the chassis rail at that point, and the really long bolt of the jates will go through the chassis using existing holes. I took some pics of mine for you: Quote Link to comment Share on other sites More sharing options...
TheBeastie Posted March 7, 2008 Author Share Posted March 7, 2008 Thanks That at least says I am looking at the right spot. Your Jates have slightly flexible sides and have clearly "taken up the slack", mine seem to be cast and will not bend in. I think I will pack two or three washers either side and it should then tighten up nicely. I just couldn't help wondering if I was in the wrong place since I remember a picture of western's where the tow ball attachments came off the same bit as the Jate. Quote Link to comment Share on other sites More sharing options...
101sean Posted March 7, 2008 Share Posted March 7, 2008 Washers shold be OK. Your JATE rings will have some 'give', mine had to be persuaded on to the front as they appeard to be 5mm too narrow (Ex mil cast ones) Quote Link to comment Share on other sites More sharing options...
Godlykepower Posted March 7, 2008 Share Posted March 7, 2008 Your Jates have slightly flexible sides There was loads of play in the rings when I fitted them.....i mean, they were moving side to side by about half an inch, so i just kept on tightening, only noticed the sides had moved in a bit when i stood up! There is STILL loads of play in them. Quote Link to comment Share on other sites More sharing options...
western Posted March 7, 2008 Share Posted March 7, 2008 Either use suitable thick steel washers or the original tiedown plates are the right thickness. I used the tow hitch steady bars as the spacer. Quote Link to comment Share on other sites More sharing options...
western Posted March 7, 2008 Share Posted March 7, 2008 To attach jate rings at the rear....you need to remove the lashing points (those eliptical shaped bits!), then the jate ring will sit on either side of the chassis rail at that point, and the really long bolt of the jates will go through the chassis using existing holes.I took some pics of mine for you: yours need a spacer, use the tiedown plates to get the sidebars straight. Quote Link to comment Share on other sites More sharing options...
western Posted March 7, 2008 Share Posted March 7, 2008 ThanksThat at least says I am looking at the right spot. Your Jates have slightly flexible sides and have clearly "taken up the slack", mine seem to be cast and will not bend in. I think I will pack two or three washers either side and it should then tighten up nicely. I just couldn't help wondering if I was in the wrong place since I remember a picture of western's where the tow ball attachments came off the same bit as the Jate. don't forget my truck is a 110CSW & yours is a 90, which have different tow hitch attachment points, Congrats on the M3 call too, just seen it. Quote Link to comment Share on other sites More sharing options...
