Pedal Rubbers
Bought the pedal rubbers for my 90 as advised!
Only the accelerator fits!!
The other two are different. One is 95mmx90mm and has the wrap around metal legs.
The other is of the same rubber style, with the retaining lip as per 90/110 but 90x95mm as opposed to these which are smaller!!
What are these pedals off and does anyone know where to get rubbers?
Thanks
Pete
P.S. This is also in the wanted sections, just because that's where the topic was started but it is probably more useful here!
Just removed & brought indoors my 110's clutch pedal rubber pad, the surface your boot goes on with the ribs vertical should be 75mm high x 70mm wide. the rear is at the inner edge of the lip is 55mm x 55mm. don't know which yours are but they are defo not 90/110 parts. my pedal metal plates are 70mm high x approx 60mm wide.
