Disco 1 rear body mount replacements
Mean Green
My 1996 300tdi D1 needs the rear body mounts replaced. My local LR specialist reconned it was possible to get replacement bracets or sleeves that could be put on over the top of the old mounts.
Has anyone ever heard of such a thing? And where to get them?
Putting a new part on top of an old one in order to affect a repair is not a good idea I reckon. Even if the new part is designed for it - I would would still remove the old. Replacing those body supports is not quite as simple as it seems - getting the nut/bolt/spacer tube, and rubbers out is fun and games. :(
Les
You can fit the new one over the old and no doubt it'll be fine for a few years, but the metal will be bare right from the start and the presence of the old mount will prevent you from being able to paint/waxoyl over it, so it's going to start rusting from day one. Cutting the old one off will only involve a bit more work and will make it by far a better finished job.
You'll appreciate it in a few years time when it's still in good condition.
Les.
