CJRH Posted March 13, 2008 Share Posted March 13, 2008 Is it ok to use Disco 1 steel wheels on a Series 2a. I need to use different rims to accommodate the brake calipers for the disc brake conversion. The only reason for this choice of wheel is that they are cheap! Cheers Chris Quote Link to comment Share on other sites More sharing options...
steve b Posted March 13, 2008 Share Posted March 13, 2008 Hi Chris, If you have the original IIA screwin/peened wheelstuds then its a bit of a no no as these are not load bearing- the wheel is a close fit on the hub dia. You could obviously swap hubs for SIII which have HT knock in studs.....or possibly drill your old IIA hubs to the right size for knock ins. SIII hubs would be the best solution really. HTH Cheers Steveb Quote Link to comment Share on other sites More sharing options...
CJRH Posted March 13, 2008 Author Share Posted March 13, 2008 Hi Steve, do I just need the hubs or the whole swivel assembly, stub axel etc? Chris Quote Link to comment Share on other sites More sharing options...
Gremlin Posted March 14, 2008 Share Posted March 14, 2008 Hi Steve, do I just need the hubs or the whole swivel assembly, stub axel etc?Chris No, just the hubs will fit. Grem Quote Link to comment Share on other sites More sharing options...
