LR 90 200tdi timing belt change
I am looking to replace the timing belt on my 200tdi 90 soon. I've been reading through Les hensons "How to" and in there it shows a pic of the parts that I need.
My question is this:-
I got a 200tdi timing belt kit from one of the suppliers, (I forget which) and the kit doesn't have the 2 round black seals in. (The timing cover dust seal and the crankshaft front oil seal I think.) Do I really need to replace these or can I not bother seeing as I don't have them??
The two seals are extra to the kit. If your crank seal isn't leaking, then there's no need to replace it, but I would recommend changing the dust seal as a precautionary measure. The seals are a 'best do it while you are in there' thing.
Les.
I see, but I don't have them. Might order some then.
