Joseph Posted March 17, 2008 Share Posted March 17, 2008 Hey all, this will be another episode of what is it, do i need it, and how do i fix it? I was having trouble with my starter so i replaced it and my rover works great now (97 disco), however, in the process with little room to work underneath, i broke something next to the starter with my ratchet trying to get to the top bolt. To describe what it is and the location, it looks like a sensor going into the engine block and its connected with an electrical wire which was bunched together with my wires going to the starter from the battery. If you can imagine the cilindrical starter popping out towards the front of the car, just at the end of it (the end closest to the front) is where the thing broke. The piece is plastic and im not really sure if its broken or if i just pulled off the cap or something (the cap attached to the wire). In any event, my truck seems to run fine, so what is that thing? Note, this may be a stupid question but please entertain it. Ill try and post a picture later. Thanks, Joe Quote Link to comment Share on other sites More sharing options...
lynall Posted March 17, 2008 Share Posted March 17, 2008 Knock sensor? Lynall Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted March 17, 2008 Share Posted March 17, 2008 97 Disco, but what engine? Quote Link to comment Share on other sites More sharing options...
First_Fleet Posted March 17, 2008 Share Posted March 17, 2008 Knock sensor? Well it didn't work, did it? Quote Link to comment Share on other sites More sharing options...
Joseph Posted March 17, 2008 Author Share Posted March 17, 2008 yes yes, i already knocked it... its got a 4.0L V8 with automatic trans Quote Link to comment Share on other sites More sharing options...
discojmz Posted March 17, 2008 Share Posted March 17, 2008 crank sensor is my guess but im a tdi man myself senses each time a timing notch in the flywheel toothed ring passes it Quote Link to comment Share on other sites More sharing options...
lynall Posted March 18, 2008 Share Posted March 18, 2008 Hs is saying the bit is halfway along the engine block so its not crank sensor and as i said a knock sensor which retards the ignition if it detects knocking(pinking). Lynall Quote Link to comment Share on other sites More sharing options...
