Mack Posted March 24, 2008 Share Posted March 24, 2008 I was planning to switch the OE alloy wheels for some kind of steel or heavy duty alloy ones. 15" tires are more easily found. The Q is what is the max tire size I could fit on a std 110" SW, without having the problem with overfenders, etc. I was thinking on Modulars or Mach types. Would I need wheel spacers...hope not. Next: Absolutely ignorant. How should I read: "offset", ""spacing between wheel nuts"..... cheers M Quote Link to comment Share on other sites More sharing options...
BogMonster Posted March 24, 2008 Share Posted March 24, 2008 You can fit 33x12.50R15 with some interference on the plastic wheelarches on standard suspension - though probably best to avoid if heavily laden unless you lift the suspension. 31x10.50R15 or 31x11.50R15 fit fine, have a better turning circle than standard and don't touch anywhere, it is a popular fitment here. If you want something taller and narrower I think some makes are available as 33x9.50R15. The number of 15" alloys around can be counted on the fingers of one hand, Compomotive VS and Compomotive DWF are the only ones I know of so unless those take your fancy (they didn't take mine) you are stuck with steels. Quote Link to comment Share on other sites More sharing options...
