inchman Posted March 27, 2008 Share Posted March 27, 2008 hi ive got a problem with my clutch.. when i press the pedal it dosent seem to be releasing the drive all the way.. ive changed the master cylinder and bleed the system. no leaks but the gears are still hard to get, anybody any sugestions? the clutch isnt slipping. cheers gary Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted March 27, 2008 Share Posted March 27, 2008 Did you change the slave cylinder too ? They should usually be replaced as a pair. As the problem persists I would suspect that that might be the culprit. HTH Mo Quote Link to comment Share on other sites More sharing options...
western Posted March 27, 2008 Share Posted March 27, 2008 and always reset the pedal to master cylinder operating rod end float too. Quote Link to comment Share on other sites More sharing options...
