Pudock Posted March 30, 2008 Share Posted March 30, 2008 I've just fitted a new recon Lt77 gearbox, filled it with expensive difflock oil and gone for a short drive and I'm not to happy. 95% of the time I cannot engage reverse gear when stopped. It will engage if the landy is still rolling. The other gears are alright but notchy and noisy compared to the one I have just removed Is there anything that I can do or adjust? I will also phone the supplier on Monday for there advice. Thanks Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted March 30, 2008 Share Posted March 30, 2008 Its worth checking the reverse light switch isn't stopping you from selecting reverse properly. Quote Link to comment Share on other sites More sharing options...
western Posted March 30, 2008 Share Posted March 30, 2008 probably the reverse light switch screwed in to far thereby preventing you engaging reverse. undo the locknut, unscrew the switch 3 full turns, engage reverse,switch on ignition, screw switch in until the reverse lights illuminate, the turn the switch another 1/2 half a turn, retighten the locknut, if that doesn't sort it it'll be the reverse gear plunger that needs readjustment. info below from Defender workshop manual Quote Link to comment Share on other sites More sharing options...
Pudock Posted March 30, 2008 Author Share Posted March 30, 2008 Its not the light as I tried it without the switch in place and still no joy. The reverse plunger on the new gear box is different from the one in your manual Western. It does not seem to be adjustable I will check the old box later to see if it has a different plunger Thanks Quote Link to comment Share on other sites More sharing options...
Bigwood Posted March 31, 2008 Share Posted March 31, 2008 Its not the light as I tried it without the switch in place and still no joy.The reverse plunger on the new gear box is different from the one in your manual Western. It does not seem to be adjustable I will check the old box later to see if it has a different plunger Thanks Not being the exspert in these maters but I am puzled by what oil you put in youre box. My LT77 has automatic fluid, the thin red stuf, the tranfer box oil is thick stuff to suite the diff. Sorry if I have miss read this thread. Quote Link to comment Share on other sites More sharing options...
western Posted March 31, 2008 Share Posted March 31, 2008 (edited) You might need more spacers or shims items 23 & 24 on the parts diagram below Edited March 31, 2008 by western Quote Link to comment Share on other sites More sharing options...
Pudock Posted March 31, 2008 Author Share Posted March 31, 2008 Well the old box has the adjustable type plunger so I have tried that but it still does not seem to help. The only effect it has is making it easier or harder to go through the gate to reverse, but the gear still does not engage. I shall have another look when I have more time. The oil I'm using Bigwood, is this Difflock oil Thanks again Quote Link to comment Share on other sites More sharing options...
western Posted March 31, 2008 Share Posted March 31, 2008 I suggest your next stop is the gearbox supplier & insist they sort it out, I can't think of anything else other than a damaged gear or syncomesh inside preventing the box engaging reverse. Quote Link to comment Share on other sites More sharing options...
Pudock Posted April 1, 2008 Author Share Posted April 1, 2008 That is pretty much what I am going to do. I need some welding done (again) at my local garage so they are going to have a quick look at the gearbox as well to see if its just something I'm missing or if its more serious. Thanks for your help again folks Quote Link to comment Share on other sites More sharing options...
western Posted April 1, 2008 Share Posted April 1, 2008 hope it's a easy fix Quote Link to comment Share on other sites More sharing options...
