Gingerlandy Posted April 3, 2008 Share Posted April 3, 2008 Hi, I have a series three on range rover chassis shorterned to 88inches will a series rear prop shaft fit or will I have to get one made up ? Quote Link to comment Share on other sites More sharing options...
RPR Posted April 3, 2008 Share Posted April 3, 2008 Unless Karmic fate is about to deal you an Ace for past good works, it will be a custom jobbie. Your only choice is to measure. However, even then, if you plan to benefit from the coil spring articulation opportunities, you will need an extra long slip joint and wide angle yolk. Depending on propshaft angles with the coils, you may need a CV jointed shaft anyway.... Quote Link to comment Share on other sites More sharing options...
tuko Posted April 3, 2008 Share Posted April 3, 2008 I have a series 3 Hybrid on a Designa coil spring chassis. The propshafts I have are standard series 3, 88". Up to now there has been no issues, but I've been tinkering with the suspension for more articualtion, so problems might be around the corner. I agree with Richard, measure! Todd. Quote Link to comment Share on other sites More sharing options...
landmannnn Posted April 3, 2008 Share Posted April 3, 2008 If you are using a series tbox and it is in the same place relative to the diffs then yes. If not then standards props will not fit. Quote Link to comment Share on other sites More sharing options...
Gingerlandy Posted April 4, 2008 Author Share Posted April 4, 2008 If you are using a series tbox and it is in the same place relative to the diffs then yes. If not then standards props will not fit. Its all range rover running gear sounds like series prop will not fit Quote Link to comment Share on other sites More sharing options...
