Scotian Posted April 5, 2008 Author Share Posted April 5, 2008 are they solid or hollow? If I but a small bend in it then welded a brace on the bent side that in effect made a straight line for the force to follow would that be ok? Quote Link to comment Share on other sites More sharing options...
ciderman Posted April 5, 2008 Share Posted April 5, 2008 Bending the arm will also effectively shorten it which will lift the diff nose. A quick fix for this is load a couple af washers onto the arm before fitting it into the bush . Quote Link to comment Share on other sites More sharing options...
will_warne Posted April 5, 2008 Share Posted April 5, 2008 A quick fix for this is load a couple af washers onto the arm before fitting it into the bush . That's often needed anyway if you've got hung up badly and bent the bush mount. Scotian, if you're going to the trouble of bending standard arms and welding on a gusset why not get hold of some suitable spec tube with an ID the same as the OD of your current arms? Then you can make up a new set of arms by bending the new tube, cutting off the ends of your current arms and sliding them into the new tube and then welding into position? At least that way you know you won't have problems. Quote Link to comment Share on other sites More sharing options...
simonr Posted April 5, 2008 Share Posted April 5, 2008 are they solid or hollow? If I but a small bend in it then welded a brace on the bent side that in effect made a straight line for the force to follow would that be ok? From a strength point of view, you are actually better off welding a fin on to the outside of the bend. Steel is stronger in tension than compression. As you try to increase the bend, an external fin will be tensioned where an internal one would be compressed. You can achieve similar strength with far less weight this way. Additionally, the external fin is better protected from ground impacts. Si Quote Link to comment Share on other sites More sharing options...
Scotian Posted April 5, 2008 Author Share Posted April 5, 2008 Very good advice, thanks. I will look into it, I want to do somthing about it before it kills my new bushes. Quote Link to comment Share on other sites More sharing options...
