landrover598 Posted April 17, 2008 Share Posted April 17, 2008 Has anyone got a wired defender dash lying about in the garage ? I need to know which wire goes to which terminal on the water temp guage. There is a male and female spade terminal on the gauge, which one is the 12v +ve feed, and which one goes to the sender ? Tar Quote Link to comment Share on other sites More sharing options...
mmgemini Posted April 17, 2008 Share Posted April 17, 2008 I thought one had a male terminal the other a female. Use a test lamp. Switch on ign. Test lamp to one wire. Try Green. The other end of the test light to earth. If the lamp lights you,ve got one. The one that goes to the sender is Green/ ?? Blue?? Again you can chek with the teat lamp across both wires and the end of the sender wire to earth. A quicker way is to look at the colours of the wire at the temp sender. HTH mike Quote Link to comment Share on other sites More sharing options...
western Posted April 17, 2008 Share Posted April 17, 2008 Green/blue trace is the signal from the temp sender Green is the 12v power Black is earth looking at my temp gauge from the connections side the green/blue fits to the left terminal, black/eatrh to the centre stud & green/12v feed to the right terminal & it's cold & blowing well outside. Quote Link to comment Share on other sites More sharing options...
landrover598 Posted April 17, 2008 Author Share Posted April 17, 2008 A quicker way is to look at the colours of the wire at the temp sender. Bit of a problem in that i'm wiring the vehicle from scratch using an assortment of wires I'll give the test lamp idea a go. Ralph, cheers, there's no earth lead, so i'll try 12v on the right terminal Thanks. Quote Link to comment Share on other sites More sharing options...
