mwoodpower Posted April 19, 2008 Share Posted April 19, 2008 is the tax on a 110 utility the same as the station wagen, or the same as a 110 hard top ie cheaper? cheers Quote Link to comment Share on other sites More sharing options...
SteveG Posted April 19, 2008 Share Posted April 19, 2008 same a staion wagon so 400 this year and 430 next. Steve Quote Link to comment Share on other sites More sharing options...
GL88 Posted April 20, 2008 Share Posted April 20, 2008 No, Steve, actually it depends on when the vehicle was first registered - see here - http://www.direct.gov.uk/en/Motoring/Ownin...cle/DG_10012524 And if it is a newer vehicle then the fact that it is a utility (post March 2001 'light goods vehicle') doesn't get you to cheap tax unless you use it commercially. So a van for private use attracts the higher charge. Quote Link to comment Share on other sites More sharing options...
SteveG Posted April 20, 2008 Share Posted April 20, 2008 Yes GL88, the 110 utility has only been available since 2007 on the new Puma. It's an option on the csw hence it comes under car tax. Now I'm really Mildly miffed off, as you make me sound like an anorak! Steve Quote Link to comment Share on other sites More sharing options...
GL88 Posted April 20, 2008 Share Posted April 20, 2008 ...if it is a newer vehicle then the fact that it is a utility ... doesn't get you to cheap tax unless you use it commercially. So a van for private use attracts the higher charge. As far as I can tell if the 'utility' is the LWB CSW but with solid rear panels instead of the rear windows then if used commercially it comes into the low bracket. I've discussed this with DVLA directly. Apparently it isn't for the manufacturers to decide what tax their vehicles will be liable for but how their customers use those which might qualify for commercial use. So irrespective of how Land Rover spec a 'utility' (or hardtop or van or whatever) they will be taxed in the higher bracket if they aren't used commercially. So now I sound like an anorak :-( . (And I guess that from DVLA's perspective this makes sense. They develop a policy on the basis that 'station wagons' never qualify for lower tax and 'commercial configuration' vehicles can but to make sure the punters don't start buying them instead or converting them they say 'but you have to use them commercially or else pay more'. Heads they win, tails we lose.) (edit for reading properly!!!) Quote Link to comment Share on other sites More sharing options...
