silvio Posted May 18, 2008 Share Posted May 18, 2008 Hi All, we've got a Td5 (125k km) which had water level with a tendence to go down; upon close inspection n. 1 suspect was the EGR radiator, as the corrugated pipe was full with black and oily water. But after removing the turbo shield, another suspect was found, and it is a plug fitted on the side of the cyl head, between 3rd and 4th cyl exhaust port. In the attached picture you can see the orange residues from the pink/orange antifreeze. The plug has an hexagonal inbus and is decribed in the parts cat ad a "water drain plug". Obviously, the exhaust manifold has to be removed, to get at the plug Advice on how to get the plug to make a good seal? Which product would best suit??? TYA Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted May 18, 2008 Share Posted May 18, 2008 Don't even think about it Silvio. Those plugs are impossible to get out unless you take the head off and give it to a good engineering shop. Best to live with the leak unfortunately. I think we had one TIG welded once. Quote Link to comment Share on other sites More sharing options...
silvio Posted May 18, 2008 Author Share Posted May 18, 2008 Yes, I feared that the coolant residues and the oxide from the head ally could make it almost impossible to get the plug out of its threaded hole... Thanks God it's not mine, but of a friend... Quote Link to comment Share on other sites More sharing options...
Les Henson Posted May 18, 2008 Share Posted May 18, 2008 Try K-Seal, it's good stuff and may cure it. Les. Quote Link to comment Share on other sites More sharing options...
silvio Posted May 18, 2008 Author Share Posted May 18, 2008 Thanks, Les! We'll see if it can be sourced here in Lower Europe... Quote Link to comment Share on other sites More sharing options...
MPS4X4 Posted May 18, 2008 Share Posted May 18, 2008 Try K-Seal, it's good stuff and may cure it.Les. I had the same problem with my Td5 90. Had it sorted by local garage and had no problems since. Simon Quote Link to comment Share on other sites More sharing options...
