TheBeastie Posted May 25, 2008 Share Posted May 25, 2008 A while back i posted about oily drips under pedals and several suggestions received including one from western I think suggesting clutch slave cylinder. Anyway it never seemed to be frequent so confess I ignored it. Today I looked in the clutch master cylinder and there is not a lot of fluid in it!!! I will top up since I have brake fluid to hand - what is easiest way to get it in since it looks a bit like a Houdini thing, but may not be as bad as I fear. So it looks like clutch slave cylinder needs either replaced or seals replaced at the least. How big a job is this? Also how viable is it to simply keep topping up till I get time, or if it would be best in garage, can afford it? Thanks Quote Link to comment Share on other sites More sharing options...
western Posted May 25, 2008 Share Posted May 25, 2008 clutch fluid under the pedal is a leaky master cylinder not slave. quicker to replace the complete master cylinder. should only take you about 2 to 3 hours depending on how quickly you work. how to guide here Quote Link to comment Share on other sites More sharing options...
BLACK CAB Posted May 25, 2008 Share Posted May 25, 2008 It would be better to replace both the master & slave cylinders. The new cylinder has a habit of doing in the old seals on the remaining cylinder. If you do both also replace the flexihose to the slave. I always find them a pain to bleed fully . Rod Quote Link to comment Share on other sites More sharing options...
Andy_LR90 Posted May 25, 2008 Share Posted May 25, 2008 Had the same problem on mine recently, the instructions from this site were excellent. I did master and slave cylinders at the same time the parts are cheap and you know that the whole lot is sound. Slave is a bit of an arse to get to though!!. Thanks to Les Henson for his time spent producing the exellent instructions Quote Link to comment Share on other sites More sharing options...
TheBeastie Posted May 25, 2008 Author Share Posted May 25, 2008 should only take you about 2 to 3 hours depending on how quickly you work. Well I guess that is about 6 months at my current rate of progress Quote Link to comment Share on other sites More sharing options...
western Posted May 25, 2008 Share Posted May 25, 2008 Well I guess that is about 6 months at my current rate of progress so get a move on then Quote Link to comment Share on other sites More sharing options...
