Mo Murphy Posted December 30, 2005 Share Posted December 30, 2005 The tyre fitters say that one of my wheel rims is leaking air, not a lot but enough for the tyre to be down to 20 psi over a week or so. Is there anything I can use to stop the leak or is it really new rim time ? I was thinking along the lines of Slime or some other leak sealant. Your thoughts Gentlemen Mo Quote Link to comment Share on other sites More sharing options...
white90 Posted December 30, 2005 Share Posted December 30, 2005 around the bead? or the rim itself if it's the rim weld the hole/crack bead some bead sealant as used for alloys(paint on black stuff) Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted December 30, 2005 Author Share Posted December 30, 2005 around the bead? or the rim itselfif it's the rim weld the hole/crack bead some bead sealant as used for alloys(paint on black stuff) From the joint where the two rim halves meet apparently Quote Link to comment Share on other sites More sharing options...
GBMUD Posted December 30, 2005 Share Posted December 30, 2005 Some sort of paint on the inside I recon Mo. At 20psi/week you should be able to find the hole/holes with soapy water on the outside. Chris Quote Link to comment Share on other sites More sharing options...
