TheBeastie Posted June 29, 2008 Share Posted June 29, 2008 I have fabricated (well that sounds more impressive than it is) a clamp for my dual batteries - two long pieces of 12mm wide angle iron facing inwards across the short sides of the two batteries and two shorter pieces pointing outwards along the outer parallel long sides of the battery. Hole in each of the outwards pointing sides to take rods to base. Bolted at 4 corners with 25mm M6 bolts. My concern is that the inwards pointing sides come rather too close to the +ve battery terminal for my liking and I do not want my passenger ejected from her seat due to explosion Would wrapping insulating tape around the angle iron near the terminals be adequate or should I try grinding out recesses with the angle grinder? Thanks Quote Link to comment Share on other sites More sharing options...
western Posted June 29, 2008 Share Posted June 29, 2008 Shape it to increase the clearance or sleeve it with heatshrink covering or just remove the lip by removing about 30mm so it's well clear. Quote Link to comment Share on other sites More sharing options...
Guest noggy Posted June 29, 2008 Share Posted June 29, 2008 with vibration and other landrover jagged movements, if the terminal touched and rubbed whilst you were using insulation tape, it may wear it away, so as ralph says, cut a recess and then coat it in tape. Quote Link to comment Share on other sites More sharing options...
Orgasmic Farmer Posted June 29, 2008 Share Posted June 29, 2008 You would not be the first to burn your landie to the ground by this method. Have a rethink and try to imagine what would happen if it all worked a buit lose or moved when on a steep bank/involved in a roll.... Do it right first time and take no chances. Might be worth cutting some small bits of wood to go around the batteries at floor level to ensure they cannot move sideways at all. Quote Link to comment Share on other sites More sharing options...
mmgemini Posted June 29, 2008 Share Posted June 29, 2008 I did think of clamping my batteries like that. Very like a series battery clamp. However I decided to do it this way... I'm ordering a pos clamp cover for the aux battery next order !! mike Quote Link to comment Share on other sites More sharing options...
