Arthurmullard Posted June 30, 2008 Share Posted June 30, 2008 Looking to increase the economy of an auto 300tdi? just a standard one!! Hope you can help? Dave Quote Link to comment Share on other sites More sharing options...
Pete Attryde Posted June 30, 2008 Share Posted June 30, 2008 When standard mine used to return low 30MPG on my normal B road route to work and a bit more on the motorway at a constant 65-70 MPH. So I suspect something is not quite right with ours. Quote Link to comment Share on other sites More sharing options...
sotal Posted June 30, 2008 Share Posted June 30, 2008 Do you know if it is EDC or not? Mine was a 95 Auto with EDC, I only did short hilly journeys and whilst I had it I did 3 or 4 mpg test and all were within 1mpg of 28mpg Quote Link to comment Share on other sites More sharing options...
Eightpot Posted June 30, 2008 Share Posted June 30, 2008 We used to get 27-30mpg, on our 300 auto - then I removed the side steps, roof rack, catalyst and reduced the fueling (previous owner had dialed it to max) We now get 27-30mpg. Quote Link to comment Share on other sites More sharing options...
thebiglad Posted June 30, 2008 Share Posted June 30, 2008 I get about 35mpg on average and more on a longer gentle run, tdi300 auto EDC - De-EGR'd and De-catted. Quote Link to comment Share on other sites More sharing options...
JDB Posted July 1, 2008 Share Posted July 1, 2008 ... .check your MPG using a GPS to record distance - not your speedo, they are notoriously inaccurate and then affected by tyre size changes as well. The only accurate way is to brim the tank, drive a long distance on the GPS (or record several small trips) then brim again, personally I always find manufacturers claims high, and most peoples high as the speedo over reads..... Not saying folk are wrong, but to get it right it helps to be accurate. Quote Link to comment Share on other sites More sharing options...
Pete Attryde Posted July 1, 2008 Share Posted July 1, 2008 Just to clarify my mileage was verified by GPS not relying on the Speedo (although it is actually pretty accurate). Quote Link to comment Share on other sites More sharing options...
Thys Posted July 1, 2008 Share Posted July 1, 2008 I get about 35mpg on average and more on a longer gentle run, tdi300 auto EDC - De-EGR'd and De-catted. My 300 Tdi Auto, no EGR, no cat: Best open road: 32 mpg Average opern road: 30 mpg City peak hour traffic @ 6km per trip: 21 mpg Quote Link to comment Share on other sites More sharing options...
samtope Posted July 2, 2008 Share Posted July 2, 2008 Even my petrol series 3 gets about 22mpg on a very hilly journey to work, to follow the general theme of your replies.. Does it smell of deisel, ie an expensive leak?! Quote Link to comment Share on other sites More sharing options...
Arthurmullard Posted July 4, 2008 Author Share Posted July 4, 2008 There is a hole in the tank and some clever sod has run a pipe all the way to the front where it slowly empties its self in to a noisy vibrating metal lump! my wife is gonna kill me!! Have come to the conclusion that there is no easy way round it but to remove the engine, check the flex plate and if its not that then strip the engine and then rebuild it with as many new parts as possible! better than a £500 s/h unknown replacement? the noise has most people baffled including the two landrover specialist that currently have it in there workshop, i am too scared to let them strip it as i am very poor at the mo! oh well the wife will have to drive the corsa for a while longer until we win the lottery!!! Thanks for all the help so far!!! Dave Quote Link to comment Share on other sites More sharing options...
