simes Posted July 9, 2008 Share Posted July 9, 2008 hi, I have an intermitant rattle on my Disco 300, Somebody has told me that it sounds like an injector rattling. Do they rattle. What causes it? How do I fix it. Do I just ignore it? Simes Quote Link to comment Share on other sites More sharing options...
white90 Posted July 9, 2008 Share Posted July 9, 2008 no unless the bolts holding them in are loose you'd notice the noise and escape of compressed air as the piston rises to Quote Link to comment Share on other sites More sharing options...
BogMonster Posted July 10, 2008 Share Posted July 10, 2008 Check the lift pump and the vacuum pump these are the most likely causes of rattles on a 300Tdi Quote Link to comment Share on other sites More sharing options...
simes Posted July 13, 2008 Author Share Posted July 13, 2008 Check the lift pump and the vacuum pump these are the most likely causes of rattles on a 300Tdi Daft qusstion probably, What do I check on the lift pump & vacuum pump? Simes Quote Link to comment Share on other sites More sharing options...
Les Henson Posted July 13, 2008 Share Posted July 13, 2008 While the engine is - erm, rattling. Put your hand on the lift/vaccuum pump. You should feel if either item is the problem. I've got 10p that says its the tappets Les. Quote Link to comment Share on other sites More sharing options...
