Velar Posted July 10, 2008 Share Posted July 10, 2008 I'd like to convert my 2.25 Petrol one ten to 3.5 V8. Because my LT77 Gearbox works fine i'd like to keep the gearbox in. Is there any adaptor/conversion ring so I can use my original gearbox? Bart Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted July 11, 2008 Share Posted July 11, 2008 Probably just a "series" landrover conversion ring, unless you want to swap the bellhousing and input shaft over from a V8 spec LT77 oh, and engine moounts too. you see the conversion rings on ebay quite often. Quote Link to comment Share on other sites More sharing options...
gelf Posted July 11, 2008 Share Posted July 11, 2008 steve parker does the kit i think. Quote Link to comment Share on other sites More sharing options...
Diff Posted July 13, 2008 Share Posted July 13, 2008 Just a point to note, If you keep your gearbox, I presume you will keep your transfer box too. It is worth noting that the 4 cylinder petrol and NA diesel 110s were fitted with a 1.66 ratio transfer box. If yours still has this, it will be very undergeared with a V8 engine unless you are fitting some very large tyres too. Normally a V8 would have a 1.4 ratio in a defender.(standard defender 90 and 110 ratio for tdi and V8) Regards, Diff Quote Link to comment Share on other sites More sharing options...
Guest noggy Posted July 13, 2008 Share Posted July 13, 2008 when he says "undergeared" he means, you will have stupid fast acceleration, and a low top speed. theres loads of places that do the conversion rings, steve parker does the kit i think. Looking on steve parkers website, it appears he does not. Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted July 13, 2008 Share Posted July 13, 2008 Or you could fit a BMW 2.8i as done by LR SA, cos that also uses the 1.6:1 box as the engine is a revver. Quote Link to comment Share on other sites More sharing options...
