blades Posted July 12, 2008 Share Posted July 12, 2008 I want to use a nato hook on a 2008 90 defender and wondered what the best way of doing it was? 1. Does a dixon bate adj bracket allow the hook to be high enough? 2. Are the 4 pre threaded holes in the centre of the rear crossmember mean't for a nato hook (if not what are they actually for)? I plan to use the hook for a sankey trailer and would like it to sit level when towing. Thanks in advance Quote Link to comment Share on other sites More sharing options...
Guest WALFY Posted July 12, 2008 Share Posted July 12, 2008 Surely a ring hitch is for commercial use only? So what use would a NATO hitch be to you apart rom a good recovery aid? Quote Link to comment Share on other sites More sharing options...
blades Posted July 12, 2008 Author Share Posted July 12, 2008 Surely a ring hitch is for commercial use only? So what use would a NATO hitch be to you apart rom a good recovery aid? The sankey trailer comes with the ring hitch... hat's why I need to use a nato hook Quote Link to comment Share on other sites More sharing options...
Chris Rogers Posted July 12, 2008 Share Posted July 12, 2008 all the TDCI defenders the MOD are using have a dixon bate adjustable tow bracket for the nato hook, looks like the best way to go. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted July 12, 2008 Share Posted July 12, 2008 MOD Defenders here all have the genuine parts (made by Dixon Bate) sliding drop plate kit. Regarding 2) yes they are meant for a NATO pattern mounting, if fitting direct to the crossmember on a new (post 99MY) Defender you will need the fitting kit which consists of a bit of plate, a bit of angle and a fist full of bolts - available from any LR dealer. I had mine fitted like that before I bought the Southdown guard. Quote Link to comment Share on other sites More sharing options...
blades Posted July 12, 2008 Author Share Posted July 12, 2008 OK, dixon bate adj it is... I see I have a choice of 3 models part no 202090 with 200mm of travel part no 202901 with 150mm of travel part no 202092 with 100mm of travel which is the best one to use (asuming I want to get the nato hitch as high as possible to allow for a level connection to the trailer?? Thanks guys Quote Link to comment Share on other sites More sharing options...
BLACK CAB Posted July 12, 2008 Share Posted July 12, 2008 The 200mm drop plate kit will enable you to get the NATO Hitch pretty well central on the rear cross member. While there will still be some downward adjustment available. Rod Quote Link to comment Share on other sites More sharing options...
