petrolhead63 Posted July 13, 2008 Share Posted July 13, 2008 yesterday with a beep all three lights popped on, abs, tcs and hill decent. All related I think on the ecu's? Then they went out and now they are on again....at one time only the abs one was on. Has anybody got any time saving pointers having had this before? Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted July 13, 2008 Share Posted July 13, 2008 This one has been done to death on this and all the other LR forums. I suggest you do a search on 'amigos'. If you put it on a pooter you should be able to see which ABS sensor it is moaning about. Quote Link to comment Share on other sites More sharing options...
petrolhead63 Posted July 13, 2008 Author Share Posted July 13, 2008 yesterday with a beep all three lights popped on, abs, tcs and hill decent. All related I think on the ecu's? Then they went out and now they are on again....at one time only the abs one was on. Has anybody got any time saving pointers having had this before? great thanks for that. I will search and see. Don't want to do it beyond death I'm puzzled why all lights come on if it is simply an abs sensor but assume it is because all three systems wont function correctly if the abs sensor is down. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted July 13, 2008 Share Posted July 13, 2008 you assume correctly - they are all controlled by the SLABS ECU most likely cause is a wheel sensor Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted July 13, 2008 Share Posted July 13, 2008 You must hope it is a wheel sensor. If it ends up being the ABS pump (that cube of alloy thingy) you will need to sell the wife into slavery to pay for it Quote Link to comment Share on other sites More sharing options...
