Tomas4x4 Posted July 23, 2008 Share Posted July 23, 2008 Hello, I need to change the drivers side c.v. joint on my 300tdi 1996 disco, but apparantaly thers two types, a 10 spline and a 14 spline, how do I know which one is for mine, without taking it off? Also what else will I need when changing the c.v. joint? Any help and advice is much appreciated! Thanks! Tom. Quote Link to comment Share on other sites More sharing options...
discojmz Posted July 23, 2008 Share Posted July 23, 2008 300tdi and late 200tdi like mine, should be the stronger 24 spline HTH Jim Quote Link to comment Share on other sites More sharing options...
white90 Posted July 24, 2008 Share Posted July 24, 2008 more like 32 spline cv's fitted if the drive member is the thin narrow type Quote Link to comment Share on other sites More sharing options...
Pete Attryde Posted July 24, 2008 Share Posted July 24, 2008 As Tony says should be 32 spline CV. Half shaft should be 24 spline at diff end on that age vehicle. Pete. Quote Link to comment Share on other sites More sharing options...
6cyltdi Posted July 24, 2008 Share Posted July 24, 2008 As above 32 spline, you don't get 10 spline its either 24 or 32, 91' on should all be 32 spline... Quote Link to comment Share on other sites More sharing options...
discojmz Posted July 24, 2008 Share Posted July 24, 2008 I can only assume the supplier the guy is buying from lists parts (As do many) by whether it is a 10 spline or 24 spline driveline (which is the more often known specification) in which case it's 24 if they list the CVs individually, it's a 32 spline as said Quote Link to comment Share on other sites More sharing options...
