jimfoo Posted August 14, 2008 Share Posted August 14, 2008 Circular saw with a carbide blade or SawzAll(reciprocating saw) with a GOOD quality blade are what I used cutting a few up. Quote Link to comment Share on other sites More sharing options...
sotal Posted August 14, 2008 Author Share Posted August 14, 2008 I used a big grinder and about £20's worth of discs.Any cheaper way to do it? It was a 9" Grinder I used last time but as I said it used about £20's worth of discs and only got about £20 for the scrap. The 9" grinder is your friend Mo As stated I was after cheaper alternatives to the Grinder! I've got myself an electric hacksaw/reciprocating saw - only cheap but I'll see how it does Quote Link to comment Share on other sites More sharing options...
rusty_wingnut Posted August 15, 2008 Share Posted August 15, 2008 if you're getting through £20 worth of discs for £20 scrap then you're doing it wrong methink. i've used the same disc for my last £200 loads........... Quote Link to comment Share on other sites More sharing options...
david1701 Posted August 15, 2008 Share Posted August 15, 2008 hacksaw and immigrant/child labour? Quote Link to comment Share on other sites More sharing options...
sotal Posted August 17, 2008 Author Share Posted August 17, 2008 if you're getting through £20 worth of discs for £20 scrap then you're doing it wrong methink. i've used the same disc for my last £200 loads........... To be fair it was a SUnday and I did have to go to B&Q for the discs so they were expensive. What type where you using - these were really thin and dissapeared as quick as you could use them. It was also a year ago or so, so scrap wasn't worth as much! Quote Link to comment Share on other sites More sharing options...
michael calvert Posted August 19, 2008 Share Posted August 19, 2008 Full size oxy bottles even with rental charge are cheep, propane will last ages, poss do 3 to 4 oxy to 1 propane, burning gear is not to dear, second hand option but make shure all arresters work and pipes are not perrished,Carl. Using Propane you should get nearer 20 oxy out of a propane assuming you mean size W oxy (tall 5ft ish bottle) and a full size propoane (47kg), aceyltene ((size F or H)3 1/2 to 4ft tall stubby things!), is nearer your 3/4 bottles of oxy they are the job, for chopping up scrap! Grinders etc are limited to the depth they can cut to and also restrict when getting into the likes of webbing and all that, Scrap yards will take it in large lumps just at a slightly reduced rate to compensate for the cutting up they have to do, if oxy / propane was the way to do it im sure you'd see them using angle grinders but you dont do you???? I would dream of letting someone come collect any scrpa i had for nothing knowing what its worth at the moment! Quote Link to comment Share on other sites More sharing options...
